Published on
Verto Plus: A True Powerhouse for Demanding Solar Installations
If you’re running a farm, a small business, or a larger home with serious energy needs, choosing the right hybrid inverter for a larger solar system is critical. That’s where the Fronius Verto Plus comes into play. Solar is no longer just about lowering bills. It also needs to work every day, in real‑world conditions, without constant attention.
You’re probably dealing with multiple buildings, different roof angles, or growing energy demand. Meanwhile, you may also be thinking about future expansion, battery storage or what happens when the grid goes down.
The Fronius Verto Plus has been developed for exactly these situations, larger solar systems where flexibility, reliability and control really matter.
Powering small businesses that need their solar system to perform reliably, day in and day out.
Built for your roofs, not idealised ones
Very few larger properties have simple roof layouts. For example, farms often install solar across sheds, workshops and machinery buildings. Larger homes and multi‑family homes may have different roof sections facing different directions or operating under partial shading.
The Fronius Verto Plus is designed with this reality in mind. Thanks to its multi‑MPPT concept, high‑current MPPTs and wide input voltage range, it adapts to complex layouts without sacrificing performance.
As a result, your solar system can be designed around your buildings, not forced into a one‑size‑fits‑all solution. Additionally, it makes expanding your solar system later far easier, which is important if your energy use grows over time.
The new hybrid inverter from Fronius is particularly suitable for more complex systems with many modules and multiple orientations thanks to its flexible application capability.
Power where larger systems need it
Once your solar system moves beyond a standard household size, inverter capacity becomes critical. Therefore, the Fronius Verto Plus is available in power classes from 15 to 33.3 kW, making it suitable for larger private and commercial solar installations.
Whether you’re powering farm operations, running equipment for a small business, or supporting higher household consumption, this power range gives you room to operate confidently. In short, it’s sized for people who rely on their energy system, not just benefit from it.
Outages happen, staying powered matters
If you rely on electricity to keep things running, power outages aren’t just inconvenient. However, many solar systems switch off as soon as the grid fails.
When combined with a battery storage system such as Fronius Reserva, the Fronius Verto Plus provides a fully fledged, three‑phase emergency power supply. This means large electrical loads can continue operating even during grid outages.
Moreover, the Backup Power Boost function allows output power to be increased temporarily in emergency mode. As a result, important equipment can be restarted immediately, helping you get operations back on track without unnecessary downtime.
Getting more out of the solar you produce
Producing solar energy is one thing. Using as much of it as possible is another, especially when system size increases.
With a battery connected, the Enhanced Power Harvest System increases usable solar output to up to 150%. Therefore, more of the energy you generate can actually be used when it’s needed.
Meanwhile, features like Dynamic Peak Manager handle partial shading automatically. As a result, your system continues to deliver strong yields even when conditions change throughout the day.
The Fronius Verto Plus is battery-compatible and can be seamlessly integrated into existing Fronius solar systems
Built to handle demanding Australian conditions
Solar systems on farms and larger properties are exposed to tough environments. Heat, dust and storms are part of everyday operation. Therefore, long‑term protection really matters.
The Fronius Verto Plus includes replaceable AC and DC overvoltage protection, automatic arc fault detection, and a robust IP66 housing. Together, these features help protect both the system and the building it’s installed on.
However, security also applies to your data.
Data security you don’t have to think about
Monitoring performance is important, but so is knowing your system information is handled responsibly. Fronius stores all customer and system data separately and exclusively on European servers, under strict security standards.
Additionally, an ISO 27001‑certified information security system and regular audits are standard practice. As a result, you can focus on running your property or business, not managing data concerns.
Designed to work as part of a complete energy system
Many larger solar installations don’t stop at panels alone. Batteries, charging solutions and connected energy management all play a role.
The Fronius Verto Plus integrates seamlessly with Fronius Reserva battery storage, offering almost loss‑free charging and discharging. Therefore, generation, storage and consumption all work together in a coordinated way.
Solar that works in the background, so farmers can focus on what matters on the ground.
A long‑term choice for people who rely on their solar system
When solar supports your work, your household or your livelihood, long‑term reliability matters. Developed and manufactured in Austria, the Fronius Verto Plus reflects decades of experience in power electronics and energy systems.
In short, it’s a hybrid inverter built for farms, small businesses, and larger single and multi‑family solar systems, where flexibility, dependable backup power and confidence in day‑to‑day performance are essential.
Photo of Daniela Dunne
Daniela Dunne
cares about making solar easy to understand. She focuses on giving customers clear, practical information so they can make confident choices that support their long‑term energy needs.
You may also like
