Published on
Vacationing with an electric car: 10 tips for your first relaxing trip
Let’s be honest: Anyone going on vacation in an electric car for the first time will, at least once beforehand, imagine the worst-case scenario: The car is stuck in traffic somewhere on the highway, the battery is running low, and there’s not a charging station in sight. Fortunately, with a little preparation, this can easily be avoided. What sounds like extra effort really requires little more than forward planning. Instead of gas stops, you’ll take charging breaks; it’s all about range rather than fuel levels; and you’ll check your accommodation in advance for charging options. You’re sure to arrive at your vacation destination just as relaxed as you used to—even when driving an electric car. In this blog post, we’ll give you tips for your first vacation trip in an electric car.
Plan your route carefullyincluding charging stops
If you’re taking an electric car on vacation, it’s best to plan your route not only by distance but also by charging options. The vehicle’s built-in navigation system automatically takes the current charge level into account and displays suitable charging stations along the route. If you prefer to use a third-party app, you may have access to a larger charging network and more detailed filter options. Tip: Keep an alternative charging station in mind just in case your preferred station is currently occupied.
Check charging maps and apps for travel abroad well in advance
Before you set off, it’s worth doing a quick check: Which charging maps and apps work in your destination country? Are there any roaming charges? Having at least two different providers on hand is a good safety net. Also, download offline maps or screenshots so you’ll always know where to charge, even in areas with poor cell service.
Compare charging rates and choose a suitable subscription
Do you travel frequently to other European countries? Then a cross-border charging subscription from a single provider (e.g., IONITY, Shell Recharge, Tesla) can be a real lifesaver—both financially and logistically. Some national charging network operators also offer individual monthly subscriptions that are ideal for travel. Here, too, comparing rates pays off!
Be sure to pack the right charging cable
Essential, yet often forgotten: The right charging cable belongs on every packing list, just like your passport and sunscreen. With a Type 2 charging cable, electric cars can charge at AC stations throughout Europe.
Estimate your range realistically and plan for breaks
A fully loaded car consumes more energy—which can noticeably reduce its range. Tire pressure also plays a role: Too little pressure increases rolling resistance and thus fuel consumption. This is easy to check and adjust before setting out. As a general rule, plan for a larger charging buffer when on vacation than you would for everyday driving. It’s recommended to keep about 20% of the battery charge as a reserve, since even electric cars get stuck in traffic.
Make good use of charging breaks and take time to relax
Charging time isn’t wasted time—it’s simply a built-in break. Children can stretch their legs during this time, pets can explore the area, and for many, a good cup of coffee at a rest stop has become an integral part of the travel experience. Those who consciously enjoy the break arrive at their destination more relaxed.
Drive in a way that conserves battery life and charge properly
Before setting out on your round trip, it’s worth charging the battery to 100% at home. On the road, the tried-and-true rule of thumb applies: charge up to 80% and then continue driving. If you also activate Eco mode, you’ll get even more range out of your electric car.
Drive efficiently to make the most of your range
Maintaining a constant speed is much gentler on the battery than constant acceleration and braking—and you don’t always have to drive at the absolute speed limit. Regenerative braking is also a simple way to recover energy. On longer trips, the electric car’s heat pump—if equipped—can also help maximize range. The heat pump uses existing heat from the ambient air and vehicle components to efficiently regulate the interior temperature—this reduces the amount of energy drawn from the battery and preserves range. (In the summer, it can also help with cooling, though the greatest efficiency benefit is clearly in heating.)
Check charging options at your destination well in advance
Is there a charging option at your lodging? If so: What rate will be charged, and are there any parking fees if the car isn’t moved immediately after charging? Clarifying this in advance will save you from unpleasant surprises. Alternatively, it’s worth searching for public charging stations near your destination.
Stay calm and arrive relaxed
With good preparation, traveling by electric car is a breeze. Minor surprises are part of the journey—if you stay flexible and don’t drive until the battery is down to the last few percent, you’ll always arrive at your destination feeling relaxed. Your first long trip in an electric car is often all in your head—with good preparation and a little flexibility, you’ll find it more relaxing than you expected. If you don’t drain the battery down to the last percent and remain open to last-minute changes in plans, you’ll reach your destination safely. And with every trip, traveling by electric car becomes more second nature.
A vacation trip in an electric car is less different from what you’re used to than many initially expect. If you tackle the planning early on—including route planning, charging infrastructure, rates, and charging options at your accommodations—you’ll quickly realize that this new way of traveling integrates well into your existing vacation routines. A thoughtful approach ensures that initial uncertainties quickly fade into the background. Once you get started, driving an electric car on vacation becomes second nature.
Photo of Karin Fischer
Karin Fischer
… is enthusiastic about renewable energies and energy communities. She writes about the smart use of solar energy and AI to optimize energy consumption in all areas of life, dispelling common myths about photovoltaics and e-mobility.
You may also like
